I'm not the LS expert on this forum, but for my LS application (still in progress), I have a stand alone wiring harness for the engine with an OBDII port, and the rest of my car (soon) will have an AAW harness for the rest of the car.
I have the same as sshamu. You will want to get your ECU modified.
Jim
We have a 2006 Pontiac gto ls2. can we use a stock wiring harness or do i need a special wiring harness.
Yes you can. I have a 1965 cutlass I installed a 2002 ls1/4l60e trans. I built my on harness using the factory harness. Here is the catch in my case I mounted the ecm to inner fender by doing this I did not have to cut and splice wire onto the existing ecm connector wiring. What that means there are only a hand full of wires needed to connect to ground and 12+ to make these engines run in your classic. None of these connections require a professional soldering job and wrap to function properly. If you plan locate the ecm hidden inside you will need to splice wires onto the existing harness. That needs to be done by a wiring expert. Some of the low volt wires that feed the fuel rail etc can cross talk if not built correctly. I'm no wiring expert but I get by. I'm planning a lsx in my nomad project and if I decide to hide everything I will be seeking the help of a harness guru. There are several over at ls1tech that you can send your harness to and they will build a custom one for you and program your ecm to delete the un needed stuff. There are also tons of wiring data on the ls1tech site should you decide to build your on harness. wait4meprefromance does a mail order tune fo 84$ includes return shipping. http://www.wait4meperformance.com/
Good luck rocky
IMHO, the last place you want to take a shortcut on, as it relates to an EFI conversion, is the harness wiring. Splices are a simple way to have your chasing issues which will do nothing but keep you very busy and frustrated.
Charlie
LS Tech and Moderator
Wayne hartwig at http://www.diffsonly.com/lsx-harness-and-computer-payment/
Can rework the harness and retune the ecm for around $400. He tunes the Ecm for life. So if you change something like a cam later and need a retune its free less shipping of ecm. For the life of that ecm. All his reworked harness come labeled. With the gm color code wires and factory connectors and no splicing.
Re wire in not hard lots of info on Internet and here... step by step on lt1swap.com...
I have questions on dbwire, but the will be later... mine is 04 vortec...
