You can thank Russ Alexander at HotRodJims for prodding me to build something that will explode.
I'll get around to post the project some day.
Thanks.
At full boost and the right tune it should be around 875HP at the block. Daily drive I'll lower the boost and should be closer to 725HP. I found out the L92 heads have had issues with the wall thickness beyond an additional bar, so I'm limited to around 12lbs boost.
