1 - 20 of 25 Posts
Does anyone know if I can fit a 60 series tire without a problem as long as it has the proper back-set on the rim to center the tire in the well ?:confused0006:
Tim it is not the profile of the tire that limits you, it is the width. A 60 series tire has a side wall height that is 60% of the width. You can go 60, 70 or even 35 or 40 but it will be the width that you have to worry about.
Jim
I guess I submitted that one wrong LOL ok what about width I would like to run the widest tire possible without having to tub it, any thoughts ?
and thanks for the reply :shakehands:
ahh very true Terry well stock springs and I will be going with a custom rear end so I can cut it as needed but what is the widest you've seen fit easily in the well ?
you and Jim have great looking cars nice job !!
I have aftermarket rallys with 4 1/2" backspacing on my 57 with stock rearend and springs. I am running 295-50x15 tires on it. They are very tight and a 275 would give as little more breathing room. Although i have had no rubbing issues thus far.
Great info Terry thanks, that at least gives me a running start for what I'm looking for I need to put some rubber on the ground with the motor I'm using..
Terry did leave your leaf springs in the stock location or move them in?
Be very careful on your calculations... I've got 275/40/18 on the rear with a 18x8 wheel and 4" of backspacing, custom width 9 inch (forgot how wide) and no springs.
To get the rear tire/wheel in or out, I have to raise frame, let the axle drop all the way and tug on the quarter panel a bit to get the wheel in or out of the fenderwell.
Charlie
Yes Rudy springs in stock location.
Charlie i have to jack mine up by the frame then it is no problem getting the wheel/tire on or off.
member
One note, you can't get a 295 tire in the stock wheelwell without rolling or trimming the fenderwell lips.
The inside of the lips is typically about 71.5-72" wide. The spring is 48" wide. So you have 12" best case in each STOCK wheel tub. A 295 tire is nominally 11.6" wide. Even a 275 tire is a tight fit, but it will fit with the correct backspace wheel. A 255 should fit comfortably.
Yep, forgot to mention that the fender lips are rolled up. I did that many years ago when i was running the L-50 series tires on cragar mags.
Discussion Starter · #13 ·
Thanks for those clarifications, I'm looking to run a set of vet style Rally's rims with derby caps (aftermarket) I appreciate the responses :shakehands:
That Nomad is going to be an awesome ride great build Chevnut :tu
Discussion Starter · #15 ·
Sorry Terry I haven't been on-line in a few I'm running 15X7's with 4.25 back-set but the way its looking unless the rear end I use is like 59" the wider tire will be an issue the rear end I have now is 61" I would need a deeper back-set in the rim to go wider with the tire.
I have 10 bolt gen2 Trans Am axle fitted(posi/disc), 60 1/2" wide, with 7x15 five spokes fitted, the max tyre size I can get under is 235x70x15 & that's with 1" taken out of the wheel arch lip...
1 - 20 of 25 Posts
