I'm posting in the forum as it it seems the closest description.
I have a 1956 sedan. It currently runs with the stock wheels, bias ply tires, and the springs are in the stock location.
I want to switch to radials. Because I've spent so much money on the car to date, my budget does not allow custom wheels or spring re-location.
Will 225R15/75 tires fit both the stock rims and the rear wheel wells.
When I bought my '56 I drove it home.
About 800 miles to go but it still had the old original bias tires on.
I bought four P235/75 R15's had them mounted and balanced and drove it on home.
They were too tall (to match original height), but otherwise worked fine on the original wheels.
WARPWR.
Thanks for the reply. I should have added that I'm lowering the car 2" front and rear. Since you were able to fit 235, I shouldn't have a problem with 225s, but I had better get out the measuring stick and see if the 75 aspect ratio will fit.
Thanks for getting my brain in gear:)
back in the 70's I was able to squeeze a pair of G60X15 on the rear, they just would go on between the stock brake drum and the fenderwell, I had to use a rubber mallet to bend the wheelwell lip in so they would not rub and they just did clear the leaf springs. I had a set of alum. slots but I do not remember the setback on them. I think G60's ar about the same size as 255-60.
on the front I haven't encountered any problems, but back in those days we wanted to run much smaller tires on the front than on the rear, I think I ran something similar to 205-75-15 but I'm not sure...
My personal opinion is that 235's are too big to be used all around.
I like a "rubber rake" with larger tires on the rear and small ones on the front; this look is enhanced if you lower the car.
I run 275 60X15's on the rear and 215 60 X15's on the front. The car is lowered two coils, and looks close to right to me
