I swapped out a bad OEM starter on one of my toys the other day. The solenoid that came out had 3 terminals; Battery, Start, and Run. The mini-starter the I put in only has 2 terminals and no diagram/instructions in the box. I know that the Battery terminal gets the hot battery lead, so no issue there. Having no place else to put them, I put both the Start and Run leads on the single remaining terminal. (The engine has HEI, no ballast resistor, and OEM wiring harness). Now the starter works (it didn't before), but it starts cranking as soon as the ignition switch is in the Run position but it won't start. Wouldn't even crank before, so I suppose it's an improvement. I know that the Start lead goes to the 2nd terminal but where does the Run lead go to now??
