1 - 20 of 39 Posts
· Registered
Oklahoma
I recently acquired a 1955 Nomad. The car is great, with one exception, it did not come with stock wheels and tires. My personal preference is the original wheels with full wheel covers, and wide white wall tires. The car has disc brakes on the front. I discovered that an original riveted 5” wheel would not clear the calipers. I bought four 15 x 6 Rally wheels from Summit, and modified them by welding nubs around the wheel to hold the wheel cover on. The process was relatively simple. After the welding was completed, I had the wheels sandblasted and power coated the car color. They turned out great. I’m anxious to get the tires mounted on them and on the car. I’m posting some pictures for anyone who might be considering doing the same thing.
Automotive lighting Automotive tire Motor vehicle Automotive design Automotive wheel system
Tire Wheel Automotive tire Window Tread
Food Automotive lighting Liquid Ingredient Drinkware
Font Rectangle Gas Automotive exterior Bumper
Tire Wheel Automotive tire Tread Synthetic rubber
· Trifive Certified Restoration Shop
I had to do the same thing for a customer quite a while back. It is a simple procedure that can be done by anyone with a welder in just a few minutes. Then powder coat or paint and ready to go.
· Registered
Oklahoma
I’m not a welder, but I found a very experienced man who used a Tig welder to build up the material. I gave him a sample of a stock wheel, so he knew exactly where to put the welds. Then he took a cone shaped grinder and smoothed them into shape. I’m very pleased with how they turned out. The wheel cover fits perfectly. Now, I’ve got the look I wanted with plenty of clearance for the disc brake calipers.
· Registered
The only observed problem with using full wheel covers over a 'rallye wheel' is that gravel can come thru the cooling holes in the rallye wheel, and then be hung behind the wheel cover to create an irritating 'rattling' sound when driving... but one can just turn the music up, or use ear plugs to alleviate this! :)
· Registered
Oklahoma
Thanks for pointing that out. I hadn’t considered that possibility. But, then again, I have no intention on driving this car on any gravel road. Have a great day!
Personally, I would not cover-up the beauty of your rally wheels...Get some trim rings and these 55/56 center caps for rally wheels.
Rim Silver Automotive tire Circle Auto part
· Registered
I don't think the nubs will affect the beauty ring attachment, possibly depending on which style of retention they use? The original trim rings for Rallye wheels used the 4 separated 'clamps' for the edge of the wheel, while later ones and repros use the continuous 'fingers' for grip... the later ones with the fingers 'might' have a problem with the nubs?
Is there a source for good reproduction center caps for '55 and/or '56? '55's have white/ivory accent, while '56's have black accent paint. Are NOS ones still available?
· Registered
So WHAT is the answer to this question:
Does anybody produce a reproduction 1955 center cap that will fit a Rally wheel?
A clear response would be great if you know the answer....
· Registered
So... will these 'reproduction' caps fit on either original, or reproduction Rallye wheels?
1 - 20 of 39 Posts
