My charging system is not working. The Alt and/or external VR are the likely problem. I really like a stock under hood look. Just got this car and it has MSD dist/plug wires & coil. Will the MSD setup work if I decide to drop the Alt and replace it my stock Gen/PS unit? I don't need 40+ Amps.
Thank you for your help.
Update: I decided to replace my external Alt with an internal 3-wire Alt. I wanted to share a special thank you to a member in Southlake TX. His help was much appreciated. The folks on this site are knowledgeable and helpful!!
There's no reason a MSD will not work with a generator. The MSD coil may use a few more amps, but not enough to be a problem.
G
The MSD should be fine down to 10 or so volts on the two large gauge wires. The small red run wire is set to work between 6 and 16 volts.
As far as a generator, I have done 5 Buick setups, converted them to 12 volts, while making them look like 6 volt systems. One of the things I did was to core the stock Buick generator out, and fit inside its case, a small Japanese car alternator, and use an extension to a front ball bearing for stock GM fan and pulley.
For the battery, I cored the stock 6 volt battery out, neutralized the acid residue inside the case, added a smaller 12 volt AGM style battery, ran the cables inside the old case to the stock 6 volt terminals, and it all looks stock 6 volt.
Just depends on how far you are willing to go to maintain stock look, and how creative you can get with hiding stuff.
