speedometer was reading 15 mph slow at all speeds so i went from a white 19 tooth gear to a brown 18 tooth gear ---comparing the two gears together the new brown gear is smaller in diameter then the white one that was in the trans will it work or did i buy the wrong gear tks
It depends on what gear is mounted on the main shaft. There are two sizes. I had to change mine in my 65 muncie to the larger one and run a 20 tooth blue gear. The gear would not mesh correctly with the smaller size.
