I have a muncie m20 in my 56, having 4th gear troubles. before i put it in the car i had it gone thru with new bearings synchros seals etc, basically a total overhaul. I have lined up the shifter following the steps from hurst. In 4th gear when i am not accelerating it pops out of gear. Also if i go to downshift to 3rd and dont need to, like when the red light turns green, and try to put it back in fourth it wont go. Have to shift into third then bring it into 4th. Tranny builder said to pull it out and he would check it but i really dont want to pull it if i dont have to. any thoughts??
Probably only the brass synchro ring was replaced, and the slider ring and/or the input gear should have been replaced too.
Other less likely possibilities are a bad pilot bearing or a bellhousing with a lot of runout.
Also possible is that the stop on the shifter is set incorrectly, but probably not.
Regardless, it needs to come out.
Discussion Starter #4
not what i wanted to hear but certainely expected to! thanks for the input......looks like i have another excuse to be in the garage and drink beer!:party0031::D
