1 - 20 of 222 Posts
I've had my 55 for 10 years now, and in that time, it's basically been the same setup. Well, I'm bored with it.
So, I've decided to do a gasser-ish setup. I may or may not do fenderwells, and I don't plan to radius the rear arches. I am not going to go with a straight axle front end, and this is where I could use some advice.
The whole car is lowered slightly, and I plan to keep the rear where it is, but raise the front. Can anyone tell me (I know I may need to just measure) if a set of factory height springs would give me that slight nose-up stance? Here's an album that will show the current stance: http://imgur.com/a/CfOc6
If stock springs won't do it, can anyone recommend something that will?
Everything else I'm pretty well set on, but if anything comes up, I'll be sure to ask!!
Discussion Starter #2
This is the stance I'm looking for, and judging by the rear, this sits pretty similar out back to how mine does now.
Do you know what the present spring and suspension is in your '55? Without knowing what you have, it's tough to say what might work. Your car looks a bit lower than stock, so I'm guessing it may have either lowering springs, or spindles. If it's lowering spindles with stock springs, then changing springs wont do much. If it's lowering springs, then installing stock, or heavier than stock springs should make the change you want.
Are your rear leafs lower than stock also?
Discussion Starter #4
Well, I'm assuming the front springs are chopped, because the spindles look factory, and everything else on this car was hacked when I bought it. I'm running stock replacement ball joints and shocks, and the shocks do look a little more compressed at ride height than normal. That would point to shorter springs, right? I was figuring stock springs up front, then maybe a coil spacer (do they exist for tri-fives?) to tweak if needed.
Saw this car at the Nationals last year.
It's probably going to be a guess and try thing. If it doesn't raise up where you want it with stock height springs, then a spacer may help. Another option are the 409 springs from a 60's Chevy. But they might be a bit stiff and ride a little harsh.
Discussion Starter #8 (Edited)
You're probably right. I figured on trying the Moog 656 springs, and if that doesn't get me there, adding some spacers. It goes down the road quite nice now (and it took some work to get it there), so I want to maintain that. If I end up having to add ball joint extensions, I'll do that as well.
Just my two cents, but your car site really nice as is.
Why would you want to ruin it by nosing it up?
You will kill the handling.
The "Rebel Rouser" sits level but gives the appearance of a nose-up attitude because the front tires are smaller and the rear wheelwells are radiused.
Gassers are cool, but so is your car.
Discussion Starter #10
I appreciate that, but I'm just bored with it. I have seriously contemplated selling it, but I figure I'll try this first and see if it rekindles the flame. It's had the exact same stance for the 10 years I've owned it. It's been largely the same the whole time. I do get plenty of compliments, and while I appreciate them, it's not why I do anything to any of my cars. If people like what I do, great. If not, fine. But I did what I wanted.
Maintaining some handling is why I'm not doing a straight axle, and a coil lift is simple to change should I want that later, or decide it's time to let the car go. The 656 springs will lift it, but they're also firmer, so it shouldn't wallow too much. Besides, with no sway bars and nothing but a rear shock relocation bar and hacked springs, the rest of the suspension is stock, so it's no corner carver anyway.
If you lift the front, why not keep it level and add some suspension goodies, sway bar in the rear, bigger one in the front, etc.
The improved handling might rekindle the fire.
Also, there is nothing like 4 wheel disk brakes.
I did all the above to my 55 but unfortunately lost it in a fire.
Discussion Starter #12
That's a thought, but I'm not really into handling so long as it's streetable and doesn't knock my fillings loose. Plus you can enjoy looks while sitting still. :D
I've got discs up front, and I planned to do the rear when I put a new rear end under it. This car has never had any sway bars on it.
This is a question many tri five members have been seeking advice on and there should be a lot of threads to gather ideas from. I personally recently tried stuffing 409 springs in my 57 150 and quickly aborted the attempt ....just too much pressure and possible a arm failure later on. Forget the ball joint spacer idea too if you only want to adjust height....Woodys has a shock kit promising to give some height as discussed in a recent thread too. The 656 coils do not give much more than an inch or so . Raised spindles ....tried them also ....too many mods and lots of issues with safety. I thought I read about some Buick colis that may be of help . So I too am interested in seeing where this thread opens up ideas ....stance is everything when searching for that look.
Discussion Starter #14 (Edited)
Keep in mind I'm lowered in the front and rear (more in the front), so even an inch over stock height up front will give me that nose-up stance. So I imagine it will be lower overall than your typical gasser, but still have that rake, which is exactly what I'm looking for.
I bought the 656 coils, and I'll throw a coil spacer on them if it's not where I want it to be.
Remove the front bumper. That will also give you that gasser look your going for.
Bill
55 STANCE
I put Buick skylark with air front springs in my 55 raised the front end about 2.5 inches so with the 29 inch slicks is has a little nose down rake. it rides and drives great.
:flag6:
1 - 20 of 222 Posts
