Hi, All--
A few weeks ago, I purchased a 57 Sedan Delivery that was Show Quailty . . . it was completed some 11-12 or so years ago, and for most of it's life since it was completed, it's sat . . . it only has 1400 miles on it since it was built.
Once I started driving it around a little bit (I think I put 30 or so miles on it), things started to fail . . . first, the 3-4 rod for the shifter fell off, and I had to temporarily use a cotter pin to put it back on . . .
The wipers didn't work, so I installed a Newport wiper motor and delay switch, and after I got that done, I went to drive it and the hydraulic clutch was dry! I found that the line between the master cylinder and the hydraulic throwout bearing had ruptured.
I had planned to install an Edelbrock Pro-Flo 4 EFI kit and convert to an Automatic Overdrive, so since fixing it would have probably required removal of the transmission, I decided not to fix that, and started the process of ordering parts . . .
I found out that many of the parts I wanted to install were on backorder or simply unavailable . . . and expensive! A Chevrolet Performance 4L65E was around $4000, the controller for it was around $1800, I needed to swap out the headers and there were few that were available--what was available was expensive, and of course the Edelbrock Pro-Flo 4 kit was $2500 at Summit Racing, was backordered and nobody seemed to know for how long.
I started calculating cost, and comparing it to what it would cost for a Connect & Cruise system, and at first was looking at the LS3/6L90E combination, but that wasn't available . . . however, Scoggin-Dickey had an LT1/8L90E "E-Rod" kit in stock, for only $3000 more, and so I ordered that . . . it should be here this week
Here is what I am "Re-Doing" on this car:
I will have to do a little bit of fabrication, for the transmission crossmember and I'll need to strengthen the existing motor mount pedestals . . . the console and shifter will require a lttile fabrication work to make that all work . . . the engine comes with stock exhaust manifolds, catalytic converters and I'll need to fabricate some of the exhaust system to either mate up to that, or eliminate the stock manifolds and cats altogether and get some headers, and of course, figuring out the wiring for the new gauges and "Push-To-Start" system will take some time, but I believe the end result is going to be amazing! Well, it's already pretty amazing, but it will be even more amazing!
I will be selling off the parts I remove/replace, and I've already posted an ad in the Classified section, complete with pictures, if anybody might be needing some parts . . .
- Swapping in the Chevrolet Performance "Connect & Cruise" LT1/8L90E "E-Rod" system
- Swapping in the Power Cool Systems Cooling module that includes a custom core support a polished aluminum crossflow radiator with trans cooler, dual 1400CFM fans and an A/C condensor
- Swapping in a Tanks, Inc. EFI Fuel Tank with GPA5 PWM fuel pump module and floatless sending unit
- Swapping in a 9" Ford rearend housing with Chevy ends, a Strange Engineering Pro-N case, 3:50 gears with a Wavetrac differential and a 1350 Yoke
- Installing a CPP "C5 Corvette/Mustang II Spindle", that uses sealed C5 Corvette sealed bearing hubs, 13" Rotors and calipers
- Converting to rear disk brakes
- Swapping in a set of Dakota Digital Gauges in place of the existing Autometer
- It has a front-tilt hood and actuator, and I'm converting that back to conventional opening with hinges and latch in the front
- I plan to adapt a '08 Cadillac DTS Console to the interior, with an as yet undetermined shifter
- Updating to a keyless "Push-To-Start" system
- I'm considering relocating the battery into the Spare Tire well . . . I could run the cables under the body and into the well from there
