Just a few points of clarification:
- I am using the ICTBillet LT to SBC adapters, and using the 4th of 5 bolt hole sets (from the front)
- This is the Wet Sump LT1 engine used in the Camaros
- The guy who built this car installed his own Rack & Pinion, by cutting the bottom out of the existing front crossmember, placing the rack inside and bolting it back together, so there are no clearance issues with the LT1 oil pan
- I am using the SBC Side Mount engine stands that someone else welded to the frame in place of the Front Mounts, and using the BBC mounts that were on the SBC that came in the car
- I am using the transmission mount from the M-22 and the crossmember that was in the car on the 8L90E; it's about 2-1/2' further back, so I had to drill some holes in both the crossmember and the frame mounts
- The stock Camaro exhaust manifolds have plenty of clearance
- The 8" Dual Diaphram brake booster required the CPP Offset Bracket to clear the left valve cover and insulator & side cover
