So, my build hit a bit of a wall, as I'm spending a lot of time on the wiring . . . got hung up on the door locks; for some reason, they aren't working at all, so I figured I'd buy a new kit, exactly like the one I have, and
they aren't working either!
Regarding the windshield wipers--I decided to hook up the washer functionality, and was pleasantly surprised to see that the nozzle tube on the underside of the left wiper transmission was there, but someone had removed the one on the right side . . . I tried finding a replacement, and even went as far as to go to Hobby Lobby and tried several aluminum and brass tubes of different sizes, but the end result was that someone had drilled that hole out too far, and getting a tube to stay in there would be next to impossible . . . my options at that point were to either buy a new/refurbished right side transmission assembly that had the nozzle for $80 or more, and go through the trouble of installing it, or to switch to a different method of delivering the spray . . . I chose the latter.
I found that 50's Fords used a hood-mounted nozzle, and those look like they would work nicely on the car . . . so, I bought a set on E-Bay, and those should be here today . . . I also bought these off of Amazon, so I've got a selection of several to choose from:
Buy 2pcs Windshield Nozzle Washer Nozzle, Keenso Universal Car Auto Windshield Wiper Spray Jet Nozzle Replacement Kit(Red): Windshield Wiper Nozzles - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
and
Buy Perfect replacement Car SUV Pickup Truck Washer Nozzle, Universal Windshield Washer Nozzle Kit, Screw-on Style Nozzles Jet Adjustable Windshield Washer Nozzle Kit Replace 47137: Windshield Wiper Nozzles - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
I will be drilling a hole on each side, inside the Rocket humps, but will have to experiment a bit to find the best location . . . then, I'll run the hoses along the underside of the hood to each nozzle . . .
I had originally purchased an aluminum tank to use as the reservoir, but it came with a small hole in the bottom of the tank with a grommet in it, and there is no way it will be able to seal with just a hose in it, so I am sending that back, and purchased a new Ford Fusion plastic tank with a flexible fill tube that I'll be using instead. I plan on mounting the tank low in front of the left front wheel, and cut a hole in the wheel well to mount the fill tube, so it will all be hidden. This tank comes with an integrated pump, so all I'll have to do is wire it up after everything is mounted--unlike with the aluminum tank, where I would have had to find a place to mount the external pump and route hoses to the tank and the nozzles from it.
Other stuff I got done:
- I am using a Dakota Digital GPS module for my speedo, and it has an optional external antenna; I bought that and got it routed
- I am converting to a "Push-To-Start" keyless entry and start system, which has 3 antennas--two for the keyless fob to unlock the car, and one for proximity for starting the vehicle--got those all placed . . . the one for the rear, I ran up the left windshield pillar and across the top of the headliner trim all the way to the back, and used the tailgate trim to hide it, exiting just under the third brake light
- The reinforcement for the hood latch on the underside of the hood for this car had been modified with a steel plate where the latch went, and then painted over; I was lucky enough to find one on E-Bay that looked brand new with a brand new latch (which I needed to buy anyway), and it's at the body shop getting painted now . . . I still need to purchase the latch support behind the grille and the striker plate.
- I had hung the fuel tank under the car, but due to the small area for the fuel pump and sending unit, trying to complete the wiring to those would have been pretty difficult to do right, so I pulled the tank back down, and have some Weatherpack 2-wire connectors coming for both those items, which should be here today; I'll be using the Solder Seal connectors to connect those to the wiring for both of those, to make sure everything has a good connection.
My "To Do" list keeps growing longer and longer, as I get further into the project . . . things like deciding on where to mount the Dakota Digital modules (which now includes a Cruise Control module), and whether to build some sort of tray to mount them all on . . . what to do with the speaker opening in the dash (thinking about putting a double DIN stereo or a tablet in there, but not sure I want to put it there or in the console that hasn't yet arrived), etc. . . .
What I had originally thought would be finished by the end of April, is taking much longer than I expected, and now I am hoping I can have it done in the next month or two . . . it's been slow going lately . . .
