Those two bolts aren't installed yet . . .
I'm using the Eddie Motorsports Latch Support and striker plate and stock latch in the hood . . .
So, I don't think you understand what I am saying . . . I'll try to explain it better . . .
When I close the hood and it latches, with the latch striker plate in the center or to the right side, the hood moves up and down about a quarter inch, but the gaps are good
When I move the striker plate to the left of the car, the hood doesn't move up and down anymore, but it ulss the front of the hood to the left side of the car, which increases the gap on the right side, and decreases the gap on the left . . . this is because the latch plate is now causing the latch itself to move to the left of the car, which is what is pulling the front of the hood over . . .
Obviously, we can't have that, so the end goal here is to have the latch in the center, and the hood not move up and down when latched. . . there are no adjustments for any of the body panels that can fix this . . .
The issue seems to be a common issue with these cars, where the hood will move up and down when latched . . . and after reading all the threads about things that can be done, and doing those things, the end result is that the hood still moves up and down, unless I move the striker plate to the left of the car, which pulls the hood over to the left and causes the incorrect gaps.
