Loking good :congrats: just can't get used to seeing ths stearing wheel on the left side of the car.
Uh Boz that would be the right side of the car.just can't get used to seeing ths stearing wheel on the left side of the car.
Looks great.Cheers GeorgeI've finally brought my Ausie assembled 4 door home after being at my brother-inlaws garage for 3 years. While she was there we replaced the the original 6 cylinder and 3 speed manual for a SB 350 and turbo 700r. Headers with2 1/2 inch system were fitted, also a automatic ididit steering column. My Ausie assembled model only had a couple of small heater cores on the fresh air vents opperated by a tap under the hood, so we fitted a heater fan under the dash on the L/H side which is connected to a heater core from a Holden Commodour. We mounted the heater core into the top of the newly constructed console, which also houses a CD player and gauges. Fitted 2'' shorten coil springs in the front and lowered the rear 2''.
The wireing has been completly upgraded along with sealed beam headlights.
The upholstry is is starting to happen, I'm doing it in red vynal with off white inserts. Seat belt mounts have been fitted in the front and back for retracatable and lap sash belts. Also the sound deading has been installed floor and roof, the doors will be done as well.
I'm hopeing i'll be finished by Christmas.
Cheers - Stu
