Good Morning,
1. Can body mounts be replaced without pulling the body completely off the frame. 1957 2 Dr Belair Hardtop
2. Where can I get rear axle bearing "O" rings for my 57
Thank You
Doug Harrell
The mounts on the '55 set into the outriggers, so I would guess yours is the same. You would need to lift the body about 1", so theoretically it is possible.
Can`t see any reason why you couldn`t change the body mounts without pulling the body. As said i`d replace one side at a time. Just make sure to unbolt all solid mounted places so as not to kink anything, in other words jack it up slowly and watch for any places not wanting to come up easily.
