After bleeding the brakes and adjusting the tie rods enough that I could do a test drive I heard a growling (metal to metal) sound when driving.
It is the top bolt mounting the rotor bracket to the top of the spindle. I am using the stock spindles, not dropped. Seems like someone else had this problem but I cannot find reference to it. Here are a couple pics.
Do I have to grind the bolt down or should I have to add some shims somewhere. Might have ruined that rotor as you can see, but hope it can be turned.
Thanks in advance for the help.
Don
Don
