The back of the block has the casting number 3737739 and the front pad has stamped F3I7DB.
The heads have a casting number 3748770 with the x58 on the outside between the exhaust manifold. I think these are 58 Corvette Dual Quad heads/ 4 Barrel. I don't think the heads match the block.
Thanks in advance for your help.
Casting number 3737739 is a 57-59 283, casting number 3748770 are 57-62 283.
DB 1958 283 Powerglide 230 HP 4 barrel carb
What is the valve cover bolt pattern, Staggered or straight across? What are the casting dates on the block & heads?
The pattern is staggered. one head says B 58 with 13 below. The other head says L 197 with 13 below that number. i am not sure where the block casting number is located. still looking for it though.
I concur with Bruce's findings......
Block...... 1958 283 230 HP...... 4bbl carb, powerglide transmission
Heads...... 1957 - 1962 283 with 1.72" intake & 1.50" exhaust valves
Looks like you've got a '58 4bbl engine there. Good find! What are your plans for it?
Happy Motoring,
Harry
Happy Motoring,
Harry
No plans for the motor at this time. I bought two cars last summer one 56 and one 58 chevy (both 4 doors) for 400.00 each. I pulled the motor out of the 58 and then sold it for 400.00
The date code on the back of the engine block is C128.
