I need help with a non chevy problem. I have a 1996 dodge caravan with a 3 liter engine and a 3 speed transaxle. I need to replace the transmission output speed sensor, but I can not locate it. Any help would be greatly appreciated. Thank you in advance for your help.
Not at the shop so I can't look it up, but wiki says...
the speed sensor on a 96 caravan is located right under the air filter and on the transmission to replace it you just need to remove the air filter and you will see it on top of the tranny.
This might help... right where cheifyoda said it was...
Thank you for the help.
Thank you everyone for the help. Sensor replaced, van road tested, and no more code. Thanks again.
