I'm adding power steering to my car. Here's the details...
Type II power steering pump - with remote resevoir
short water pump
high mount alternator bracket (by March) - mounts inside of valve cover
crankshaft has double pulley
water pump has single groove pulley
The problem i'm having is the alternator sits too far forward....i think.
The questions....
Does the power steering pump drive off of the 2nd crank pulley groove (closest to radiator)?
Does the alternator drive off of the water pump and the 1st groove of the crank pulley (closest to motor)?
I think the answer to both of these is yes...
If that's the case what can be causing my problem? I checked the alt bracket and the alternator cannot be moved any further back without grinding down the mount on the alternator. It doesn't look like the alt pulley can be any closer. Feedback and guideance is appreciated. Thanks!
short water pump
The questions....
