NEW APPLICATION ANNOUNCEMENT!
RideTech StreetGrip For 1955-1957 Chevy (Tri-5)
Now Available For Pre-Order!
Ridetech has recently released the Tri5 StreetGrip kit. I know a few of you have been asking about some of it. The StreetGrip kit is designed to be bolt-in and greatly improve the handling while providing a nice ride. I personally know the owners of the cars we used for development, to say they were blown away would be an understatement. They couldn't believe how well they rode and handled. Mike said he didn't know you could make a 55 drive so well and his is even manual steering. There are some bullet points at the bottom of this post that went out in our newsletter, but I wanted to talk about them a little more.
We replace the the OEM leaf springs with a composite leaf spring. The Composite leaf is well proven in Corvettes and other vehicles. It won't sag or take set, it is very predictable in spring rate and ride height. We use a Delrin Bushing setup to eliminate flex and allow for free movement at the bushings. Freeing up the movement of the bushings helps with ride quality. The material we use for the bushings is Teflon infused to provide self-lubrication. I have had this bushing setup on my big heavy Suburban for several years now. We used it for one of the test mules due to it being big and heavy.
We use a Dual Rate Coil Spring in the front, it is designed to ride around on the softer rate, but transitions to the stiffer rate when you hit a big bump or roll into a corner. Hyperco builds all of our springs, they are the leading coil spring manufacture in the United States.
We use Delrin bushings in the control arms to replace the OEM rubber bushings. This eliminates deflection and frees up the suspension movement. Once again, free suspension is better riding suspension.
We use a tall upper balljoint to improve the camber gain on the front suspension. Improving the camber gain helps to improve the handling of the car. The more tire tread you keep on the ground in the corner, the better the car will handle. Back in the day when these cars were designed, they used bias ply tires and handling wasn't as big of a concern as it is today.
The kit comes with an 1 1/4" diameter sway bar and the bracket to bolt to the OEM arms. We use a Delrin liner in the sway bar bushing to allow the bar to move freely in the frame bushings.
All of the StreetGrip kits come with our HQ Series Smooth Body shocks. The HQ Series is a Single Adjustable Monotube shock. The Monotube has a large piston for better suspension control and less impact harshness. Plus, all of our shocks come with a 1,000,001 mile warranty. The biggest improvement we made on the Tri5 is the rear shock setup. We built a staggered shock setup to help eliminate wheel hop. They came with both shocks in the front which done nothing to control axle twist. GM eventually switched to a staggered shock setup on the performance cars that had leaf springs. The main reason for this was to control wheel hop. The brackets are bolt in and use the OEM location as a reference point. The only thing we use the original hole for is a locator.
This isn't a universal kit, it is designed specifically for the Tri5. I have also posted some links to our website that go into more detail about the kits. Be sure to click on the other videos at the end of the main video. It talks more about the specific parts.
http://www.ridetech.com/store/streetgrip
TRI-5 KITS SCHEDULED TO SHIP MAY 2016
These are some bullet points we sent out in our newsletter, I posted them in case I missed something.
• Easy to install - direct replacement for factory suspension - no other modifications necessary
• RADICAL improvement to ride quality and handling performance
• Vehicle-specific dual-rate front coilsprings offer the best of both worlds...ride quality AND crisp handling
• Delrin front control arm bushings eliminate unwanted movement and stiction in front suspension
• Composite rear leaf springs offer linear spring rate and saves 70lbs of unsprung weight!
• Delrin leaf spring bushings regain lateral stability missing with rubber or poly bushings
• Tall balljoints dramatically improve OEM camber curve to give your car a much more stable feel through the corners
• Larger front and rear swaybar minimizes unwanted body roll through the corners
• Delrin swaybar bushings eliminate unwanted movement and stiction in the swaybar to improve ride quality and handling performance
• Vehicle-specific RideTech HQ series rebound adjustable shocks offer the ultimate in ride quality and handling performance
• Staggered rear shocks eliminate wheel hop; upper mounts are reinforced for extra strength
