After 2 years I finally finished up my engine and got it in the frame and fired up to break it in, but I cannot keep coolant in the radiator or it from overheating. The engine is a 1982 350 block with 906 vortec heads. The shortblock and heads were rebuilt with beehive springs installed. I have also drilled 6 holes in the themastat for bypass issues. I have bypassed the heater hoses by connecting the water pump to the passenger side of the intake as shown:
https://plus.google.com/u/0/photos?tab=mq#115572865768867314195/posts/TY6JmHmhq7t?pid=6127635058459368978&oid=115572865768867314195
I'm hoping it has something to do with this routing being incorrect. The main issue I have is it runs for 10 minutes or so and then starts to get warm and blows water and steam out the radiator....and not just a little. The water pump and radiator are new. I fear I may have a cracked head, but it is not just bubbling...its is blowing water like a geiser like it has huge air pockets.
Any one have any ideas to go from here? Radiator pressure test? Pull the plugs? I know you can get the kits to test for gas fumes in the coolant from Napa, but I cannot keep coolant in it to even do something like this.
In addition, I've noticed the passenger side exhaust being warmer than the driver side because the stainless exhaust clamp has turned colors on the passenger side and the driver side still looks new. I initially just thought it had something to do with the cam break-in, but I'm now wondering differently. Should check it with a infrared temp meter or something?
Thanks in advance for any ideas, suggestions or information. I'm stuck at this point.
