1 - 11 of 11 Posts
I have read a lot of material, both pro and con, on nitriding as a process for preventing lobe wear for a solid lifter camshaft. My 57 is being restored to stock specifications for the dual-four 270HP motor, and I am using the 3736097 camshaft. The engine shop and another builder whom I have consulted are suggesting that I shift to a roller. I do not intend to race the car. If a good zinc/phosphorous additive is used with a good quality 10W30 oil would I be likely to get lobe wipeout? In general, what are your thoughts about nitriding for a sbc non-racing use?
Thanks.
VetteGuy
Is this on an existing cam or new unit. I havent purchased any internals in a very long time but it seems that they have a coating of sorts.
As for oil, you mightndonsider some of the new high zinc oils like brad penn and the like. Cost a few extra dollars but made more like the oil these motors need.
If you stay with stock spec valve springs, about 80lbs, the cam should last a long time, if it's broken in properly and maintained with zinc additive or "break-in" oil(has the zinc in it already). You might want to read this article about oil and zinc:
http://www.nwquattro.com/forums/index.php?topic=1419.0;wap2
LS Tech and Moderator
Whats the price on Nitriding it? Might be worth it. I seen prices from $100+ for car stuff most the aircraft internals are nitrided. But the oils used in aircraft still have lots of zinc anyway!
If as mentioned run a good oil and or zinc additive it will be fine.
I've never heard of nitriding a camshaft - only a crankshaft.
It's a fairly specialized heat treating process. Chevy nitrided some crankshafts over the years - but certainly not all.
Your existing camshaft is probably induction hardened, or a similar process. Nitriding an already hardened material probably isn't even possible.
Comp Cams has patented a process for Nitriding flat tappet cam shafts called Pro Plasma Nitriding. I toured through Comps facility in Memphis a few years ago and they said they do Nitriding in house.
You can contact them "Cam Help" at 1-800-999-0853 to help in your decision.
Thanks, Tom. The article gets into the details, which is what I need. Probably should read it two or three times.
Dick Nance
REMEMBER WHEN of Newport
P.O. Box 130
Newport, VA 24128
X2
This would be my choice also. For the cost to retrofit a '57 SBC for a roller setup, you could buy a darn good plasma cutter.
1 - 11 of 11 Posts
