Have older chev trk stock. It sat for two yrs and front calipers stuck.
replaced front calipers, and new rear brake tee and hose. replaced with
new master cyl.....only getting fluid to one caliper..Mater cyl was primed.
I did notice there was no fluid at rear Tee when I replaced it...pumped
brakes several times and never any fluid except at one caliper...Does
this sound like I have line blockage somewhere? I still have the old stock
front rubber brake lines, and all other metal lines are stock too. Trk is
30 yrs old.
Did you replace the rubber hoses to the calipers?
I did not replace rubber hoses to calipers, only the one in rear with the tee.
saw no evidence of leaks...The new master cyl is identical to the one I took
off, and I checked that it did have pressure from both ports before installing.
