CPP offset booster bracket, 1.125" master cylinder with combination valve disc drum. (Dual 8" booster is bad) system had worked well for 2 years but just failed.I would recommend not shipping booster to save on shipping cost I can give correct length needed to shorten the booster shaft.Note the idiot I talked with at CPP tried to convince me the standard booster was the same he is wrong the shaft must be shortened. $125+ shipping for all or $100 bracket only. These are necessary when retaining original generator mounted PS along with a generator relocation bracket that moves the generator in closer to the valve cove & still uses the original adjustment bracket I also have that bracket. Helpful with valve cover clearance for BB install or Tall valve covers.
