· Registered
Not sure the rad in my stocker 55 is original,it is a 265 with p/g.The numbers I see are =R03 over B55, on other side says Harrison over 3133045. Can anyone tell me ifthis is the orig/correct rad for this car?? Thank you for any info..Wayne
· Trifive Automotive Electrical Wiring Expert
· Registered
Thank you both very much for quick replies..Old memory does not work so well lately. I have just pulled it out to put a shroud on it & just did not look like a good fit. Will have to look/think some more on it in the morning.. Thanks again.. Wayne
· Administrator
:anim_25: Wayne are you fitting the shroud so the fan blade is 1/2 in the shroud & half out.
