Greetings, Can someone tell me what front suspension came on a 56 pickup? Did they have a drop axle with leaf springs or independent suspension like the cars did? I'm in the process of getting one, and it has a 4X4 setup from a 76 under it. I was wondering how difficult it would be to find original suspension and put it back to stock(ish). I have no plans to drive it in snow or mud, so it's kind of a wasted effort to me. I had a 74 K5 Blazer in the past, and it steered horrible! Thanks!
Craig32, future Tri5 truck owner
I believe they are a straight axle. Did they just change the axle or did they put the body on the 76 4x4 frame? A lot of people do that so it might be worth checking.
:anim_25:
He said it was the original frame. Hope to see it soon, it's on the way from Nebraska.
Hopefully you will just be looking at finding a front axle and removing the transfer case, may have to re-fit a driveshaft.
post a pict when you get it.:D
Todd, I'm good - I got the truck a month ago and it is the original frame. I bought an original axle for it and will swap it when the weather is good, no heat in the garage!
