1 - 16 of 16 Posts
· Registered
hi forum i have a question why would the coolent leak out out the over flow tank after i turn the car off and it sits for a min. the temp is ok setting and driveing.i have a new rad and cap new overflow tank and cap. thanks :confused0006:
· Registered
First off, there are two kinds of coolant tanks. One is a simple "overflow tank", unless you empty it yourself, it will overflow eventually. Second is actually a "coolant recovery tank". When coolant get hot and expands, it goes to the tank, and when coolant cools and contracts, water is drawn from the tank back into the radiator.
A coolant recovery tank must have a tube inside it to siphon the coolant back into the radiator, and this tube has to be immersed in coolant for it to function. The radiator cap must also seal at the bottom seat and at the top of the neck. This type cap has a gasket at the bottom for the bottom seat seal.
It is normal for coolant temperature to rise when you shut off the engine. The reason is that the block and heads are still at operating temperature, and heat transfer from the metal to the coolant can continue without any coolant flow. But there is little or no heat transfer from the radiator to the surrounding air because there is no air flow.
If you have a stock type downflow radiator with a top and bottom tank, you probably don't need an overflow or recovery tank at all if your radiator is working right and you have enough airflow across the radiator. All you need to do is run enough coolant in the top tank to cover the tops of the tubes, but leave an air gap for expansion. You may need to experiment to find the right level to fill when cold to avoid losing coolant. There is no loss of cooling capacity as long as coolant covers the ends of the tubes. There is no harm in using a coolant recovery tank with a downflow radiator, and you can fill it to the top if you have one.
A crossflow radiator is a bit different. There, if you have an air gap at the top, you may leave the top tube(s) not covered with coolant, and if that happens you lose cooling capacity. So you really need a coolant recovery tank if you have a crossflow radiator.
Actually there is a third kind of coolant tank. It's called an expansion tank, and its highest level is above the top of the radiator. The expansion tank has a pressure cap on it, and there may or may not be a pressure cap on the radiator itself. A lot of Corvettes have these from the factory, and my late model pickup has one. With the expansion tank, there is a large air gap above the normal coolant level, and the normal coolant level is above the top of the radiator. It's rare to see one on a 55-57.
· Registered
hi i have one of thouse after market tanks that are crome and long it has 2 outlets on it 1 hose go to the top of the rad and the outher i guess its for overflow so if it over heats ?????
· Trifive Automotive Electrical Wiring Expert
That sounds like a recovery tank. The hose from the radiator should go to the outlet that is always covered with coolent as Rick explained. The overflow is the outlet that extends up close to the top of the tank. Make sure the hoses are on the correct outlets.
· Registered
I'd say Don is right, i have the same style tank as you have..one tube goes up inside the tank a couple of inches..the other is just flush with the bottom..have a look if you have the hose on the wrong fitting:)
· Registered
well i guess i can only put the hose on one of the tubes because if i use the outher tube then is just leak all out so i guess its right? so maybe the rad cap does not hold pressure
· Registered
I like that engine compartment :tu :tu :tu :tu
And I agree with Don & Mike :)
I thought "leaking out" was the problem? :)
It's possible that you don't have a recovery cap that doesn't have the vacuun valve in the center.
· Registered
victor Notice the cap in the picture has two rubber seals. One on top one on bottom is yours like that? If its like the one the picture the recovery tank should work like this. As the radiator heats up the coolant expands and overflows in the recovery tank. When it cools down coolant is drawn from the recovery tank back to the radiator. If thats the case the line coming from the radiator needs to be hooked to a fitting on the recovery tank that has a internal tube that drops some were near the bottom of the tank. If your cap only has the bottom seal you need to leave room in your radiator for the coolant to expand when it get to operating temp. Otherwise it will puke out coolant. Hope that helps Ron
· Registered
Discussion Starter · #13 ·
thanks Ron , no my cap on the recov tank does not look like the one in the picture. so what you are saying is that i sould drain out some coolent from the rad ? maybe just below the neck line thanks
Sorry Victor, the cap I posted the picture of, is the radiator cap, not the recovery tank cap. I was trying to show the valve in the center of the bottom seal is for vacuum in the radiator to suck the coolent back to the radiator. Some radiator caps do not have the valve.
The recovery tank cap is not critical, it just keeps fluid from sloshing out.
· Registered
That is correct, There are two type caps. You can use a overflow tank but you have to drain it every so often. Most race tracks require some sort of reservoir to prevent coolant overflow on the track. The main reason thay started the recovery setup was to allways keep the radiator completely full of coolant. Its adds coolant capacity and stops air from getting in the system causing oxidation. There are kit available to convert to a recovery system.
1 - 16 of 16 Posts
