The condenser gets removed as well. Pull the points and condenser and the negative wire from the coil. Place in the pertronix and run the negative to the negative on the coil and positive to either the ballast resistor if you have one or the positive side of the coil and your done!How to change from points to pertronix igniter 2 wires but what about the condenser. Thanks for all the headliner tips.
