1 - 11 of 11 Posts
my 4speed pops out of 3rd gear every now and then. never did it before any ideas whats happying? thks larry
Check your shift linkage, it may not be going all the way into gear.
As mentioned check your linkage adjustment and also the stops on the shifter if so equipped. If that don't cure it then it is time for a rebuild. :anim_25:
-Bruce
Yep as said first check your shift linkage. My trans started doing that this spring, got under the car and sure enough there was slop in the Hurst linkage when in third, just enough to let it pop out of gear every once in awhile. I adjusted the linkage and it hasn't done it since.
While it can be the shifter, it is usually sliders and synchros as wraplock said. And if you drove it for any length of time with the shifter causing the problem, that will put a great deal of wear on them. So one thing leads to another.
I don't believe the synchros have anything to do with it popping out of gear. If it was a synchronizer issue the trans would just not shift very well. Once it gets into gear the synchro ring is just along for the ride. Check the shifter. If it's not it's either wear in the shift forks, slider, or the gears are getting worn.
My Borg-Warner T10 was notorious for the lingage issue. Go over everything including the stops. A little locktite solved the problem for me.
i`ve rebuilt muncies for 30 some odd years....if your shifter is adjusted correctly and operates correctly....the problem is with the sliders or hubs,the scissors on the cover plate, or the engagement teeth on your gears...syncros have nothing to do with it,as they just act as "brakes" to engage the sliders...if you do rebuild the tranny,and the engagement teeth are worn...the newer "torq-loc" sliders sold will help your tranny stay in gear....also check all other above mentioned items for repair,and replace as necessary....good luck!!!!
friends,Alan
1 - 11 of 11 Posts
