Has anyone did this before and have any plans they wouldn't mind sending me. I have located a cowl actuator that I think I can mount and have the gauge pod under the speaker cover and make it come on when the key is on. :p3:
I haven't done it on a tri-five but I did have a power actuated cowl vent on my '34 roadster operated by a spring loaded toggle switch. The concept is certainly doable but I would think you need to put some thought into it - gauges (and wiring) need to be accessible - this could be a challenge if you put A/C in the car. The gauge enclosure needs to closed on top and sides so nothing is visible open or closed - you could consider using some strip gauges similar to Dakota Digital to minimize the opening size. Sorry I don't have any plans but it is a good idea - I know there are some aftermarket gauge packages (3 gauges) that replace the speaker screen so maybe you could modify one of those (turn it upside down?). Good luck. AWC
That is a Killer-Cool mod! Let us know that goes. Take some photos if you don't mind.
I will try to cut a template and take some measurements. I have VintageAir installed, I think Classic57 has a good suggestion about the amount of room under that area of the dash.
Interesting...
