I have just installed a new 8 inch power booster and new master cylinder on my 55 Chevy, but there doesn't seem to be any improvement over the non-power. There appears to be good vacuum but i haven't put a guage on it. the engine is a stock 350 with Edelbrock carb and manifold.
The master cylinder is 1 inch bore, which i was told would be better than 1 1/8 to use with the power brakes. the lines going to the porportioning valve are 3/16. the vendor assured me this was ok. i have front disk brakes with drum on the rear.
does it matter if the vacuum line fitting is at the top or bottom?
i would appreciate any advice.
