OK, I have put the conversion kit in my 55 Belair and have a question. My steering box with rag joint come right up to the firewall with no room to install the bracket for the column. My question is, is that bracket necessary or can I leave it off ( new column and CCP 500 box) still utilizing the bracket under the dash.
Thanks in advance - Joe
Hi Joe,
For my 500 installation, I didn't use the original steering column clamp on the engine side of the firewall, installed an aftermarket column clamp that installed on the driver side of the firewall.
Regards, Doug
Discussion Starter #3
Hi Joe,
Regards, Doug
Thanks Doug, sounds like a solid plan
I used a plate on the inside that covers the odd shaped firewall hole and has two tabs for a clamp. May have been from CPP. Not sure. I painted it black and it closed up the firewall nicely.
That plate is a CPP item and it does a nice job of closing up the opening as well as securing the base of the column.
Agree Bruce....I put that one in my 55 HT (with some minor mods)
