Hey guys thanks for the input. A little bit more on the engine. It has only a couple hundred miles on it. I did not do the rebuild on it.Its a 30 over 400 with a comp cam and cast over the counter angle plug heads with roller rockers. the manifold is an Edlebrok with a 4160 holley. The didiz is an old points style that has apertronix II conversion. I put a 45000 volt coil on it today and got rid of the ballest resistor to get 12 volts to the coil all the time. I also opened the plug gap to .050 and reinstalled. I ran the engine and it did much better. But its not right yet. I did hook up a vacuum guage and had 18 inches steady, even with that cam. Ill do the timeing tomorrow(around 10 12 initial) and put in a new set of plugs and then
,frankley, I do not know where to go from there. By the way I'm kind of rueling out the power valve because it actually idles pretty well for that cam. Any, thanks for all the help so far. Sharkey 5557.
