1957 Chevy Bel Air Sport Coupe
Hi Guys
Asking for a friend... For any of you that have put power windows in your tri-5, does anyone know if any of the vendors make a power window harness that would go from the door switches to the fuse box? Or did you just build your own harness? The car has the AAW Updated full harness/fusebox system in it.
Doug
I have the same harness in my 56 , I used Auto City power windows and there harness was a simple hook to the AAW accessory connector . They might sell the harness by itself . Their power window wiring harness also has the wiring for a power seat. Don
Hi Guys
Doug
I did not do the PW install on mine, but used the AAW and Shawn had no problem using it and they work fine electrically. :bowtier:
Just to clarify are you talking about AutoCity Classics in Minnesota?
Doug
As DavidC stated. I used the Specialty Power Windows with 55 AAW harness that hooked up fine. Did use Auto Classic glass and frames and gas tank with no problems. :bowtier:
Hi Guys
Doug
Purchased my harness from Electro-Life Inc., 5990 Northwest Highway, Chicago,Ill 60631. Was $76 plus shipping. Worth checking.
