Status
Not open for further replies.
1 - 20 of 29 Posts
Hi Guys, New member with a just purchased 56 Bel Aire 4 door. Have a Powerslide problem. It will not shift into high gear when in drive setting. Worked just fine at first, then started slipping between gears, and now no high gear. I found I was low on fluid, and filled it up with no improvement. Do I have to pull this sucker out, or are there some things I can attempt while the trans is in the car? I am familiar with T10 4 speeds, but have never touched a auto. Printed out Dave's book, thanks.
Thanks, It will come in handy now that I have found a leak in mine.
Dennis
Hello ... my 'Glide leaks fluid mainly after it sits fer a coupla days. Also my main prob now is that when you go to start it it has a tinny knockin sound that I believe is the flexplate. Haven't been able to locate one that doesn't have some cracks in the hob area. Where can I get a new one or at least a good used flexplate.
P.G.
thank you for the info this site is awesome i recently rebuilt my P.G. with my thirteen year old son.Took it for a test drive first worked great no reverse wich i think is a linkage problem but when it shifted into second it would slip.When i pulled onto the curb in my driveway i lost all motion. like a chevy she got us home. having more time than money we are going to pull it out and go back through it.the info here is priceless.
Anyone know what the gear ratios are on the PG.....I want o see how the low gear compares with the 200 and 700-R4.
The ratios for a cast iron Powerglide are 1.82 in low and direct (1:1) in high.
THANKS Farm Boy :):tu The 200 has a 2.74 first gear, while the 700 has a 3.06 :confused0006:
Powerglide Dip Stick
Would like to get my hands on the engineer who designed this stubby thing. Any ideas where I can get an extended handle one, so I don't have to use a step ladder to check the tranny fluid level?
If you want, I have a 57 Powerglide that was replaced with a 700R4. I rebuilt it 3000 miles ago - ANYONE want it!? $100 and you pay the shipping!
Mac
98660 zip
Thanx
Downloaded the pdf and saved it successfully. I have a leak in my powerglide where the speedo cable enters the tranny. Is there a seal supposed to be in there.
Rick
1 - 20 of 29 Posts
Status
