1 - 2 of 2 Posts
Hello again all. I have a powerglide question. I have a 57 belair four door hardtop and recently had problem with it not going into reverse. After reading several posts I determined that it was the rear motor mounts. Replaced them and all was well. After adjusting the shift linkage according to the manual now the only way I can get it to upshift is to slightly mover the shift lever down a bit into low and back up to drive and if shifts fine. It does not slip and seems to drive great after that. Can anyone tell me if this is a linkage problem or not?
Thanks for all.
Jim
The TV rod adjustment is more than likely the adjustments you need to look closer at.
The kick down will not operate if your over a certain milage, for me I would put the pedal to the floor at about 40m/ph and it would drop from second to first.
1 - 2 of 2 Posts
