1 - 3 of 3 Posts
Did anyone have to shim one side of the where the built in core support on the PRC radiator attaches with two bolts on each side to the front fender. When I close the hood, I can see the side of the hood where the hood bracket attaches rubbing against the bracket on the core support. The passenger side front fender around the grill area also seems to be tigher. I'm wondering if a single shim in the back bolt of the core support bracket on the driver side would push the passenger side fender out a bit.
John
one more thing that I thought of, it could be that your radiator support is to high so when the hood comes down it hits on the angled part, the only way out of this would be to take out some shims at the bottom and you may have to slot the holes in the fender or the support, just a thought
1 - 3 of 3 Posts
