Today, after getting some sage advice from a local club member over the weekend (forums are great, but nothing beats personal face-to-face), I finally took the plunge and ordered the CPP minimum offset front kit (8" dual diaphram, drilled&vented rotors) for stock spindles through Danchuk. Two things may interest you guys who were following this thread last week:
1) The phrase in mgchevy's listing for his zero offset disc brakes really means what it says: "No original steel wheels work with this klt." He suggested a different kit of his, which "should work." OK, next?
2) I called CPP today to order their kit, and the first "tech support" guy put me in touch with a second, who had to ask a third,....if this kit worked with stock 15 inch steel wheels? None of the three could say for sure that it would work, and why it might not, except that "some guys grind the calipers to make it fit."
3) I called Danchuk just after that and had it explained to me that not all stock 15" wheels are the same because they were made by several different manufacturers. That's a new one on me. So if they don't fit over the caliper, the problem can be fixed with an 1/8 inch spacer behind the wheel (or finding a stock rim that does fit).
Overall, I am staggered by how much confusing information is out there, and how hard it is to resolve something that seems pretty straightforward to me, given the years and thousands of people and cars. It's taken me almost two years to get to the point that I felt reasonably comfortable plunking down $700. All this takes nothing away from my appreciation for all your advice and willingness to share time and experience. No front drums.
Later, guys.
Later, guys.
