Received the new Moser Engineering 12 bolt today. All nice and pretty new.
Going to change out the brake lines while replacing the rear-end but how can I hold the brake ling to the housing. You know the little clips that come on the OEM rear-end. Thought about tie straps but that looks kind of hokey. Anyone have a suggestions?
with a welder!! seriously though, I put a little piece of vacuum hose on the line where I would be clamping it when fabbing it, then I use a hose clamp covered in heat-shrink to secure the tube. makes for a nice clean install.
Mine were spot welded, drilled them out and taped them with a hammer. Ground them smooth drilled the holes thru the brackets. Then took the wire welder and plug welded thru the holes to the new housing. Ron
