1 - 12 of 12 Posts
I finally got a chance to pull my gauge cluster and fix my seized speedometer. Put in a new speedo cable through the firewall first. I had to spend a lot of time washing it out with wd40 and spinning back and forth before I finally felt it was not binding and was smooth. Put a drop of sewing machine oil in the hole and put it all back together.
Speedo is working again, very slight jitter on the needle at 50+ mph but that might be normal if I recall.
Can I just say I hope it lasts a good long time because that is not a job I want to do again anytime soon.
sounds good bobby. :tu
Like I always say at work, the second time I do it I'll be faster!
Next up is putting in the heater control valve you so kindly sent me, and mainseal (gulp), and dual manual master cylinder.
50 miles and it is still working thankfully. This is the only car that I WANT to see miles piling up on the odometer. Need to know how far I am going since the top end rebuild, and obviously for maintenance monitoring.
Very cool! Just keep and ear and eye on the speedo. Future screeching noise means you need to go a little deeper in the speedo. Wildly jiggering means the same thing.
If this one goes anytime soon, I'm putting in a new one, pulling clusters is not the kind of thing I want to do on a regular basis~
Blue and White 57 looks nice
1 - 12 of 12 Posts
