1 - 20 of 32 Posts
I am planning to have some work done on my 57 Nomad and I am wondering if putting in a new rear end is money well spent. The car has a 350 with a 700R4 from Bowtie, but I expect that the rearend is original. The rear ends from Ecklers are pretty pricey. Any info and suggestions would be appreciated
member
What are you trying to do with it? Unless you're really going to hammer it or race it, I think a stock rearend will hold up pretty well to a mild 350. Especially behind an automatic. I had one with 4:11 gears and a posi behind a 427 and 4-speed and never had any problems, even when I smoked the tires. ;)
Yup, gotta
agree with Laszlo on this. Being "Trendy" can get costly.
If you are going to get a new rear end why not get a bolt in 12 bolt? It's cheaper, lighter, takes less power to turn and it's a Chevy rear end. Moser makes bolt in 12 bolt rear ends for the '55 to '57 cars. You could also build a rear end from many other cars for less money. You are far from needing a 9 inch due to strength.
If you must go Ford 9" a friend of mine has a Strange Engineering nodular iron third member with a spool and new 4.86 gears he'd love to sell you... It went to a rail dragster he no longer has... lol
R.I.P. 3-19-2017
9 inch Ford rear end
I have a 57 Nomad with a 9 inch Ford Rear end. It is out of a Lincoln Versailles and comes 2 inches narrower than a stock rear end (about 58") and has disc brakes as a bonus. I needed to put lowering blocks in to get the e brake levers to clear everything. These are 28 spline axle rear ends but will hold up to all "normal" driving.
I went for an F9 out of a mid 70s Bronco. Good fit, but I had to have the axles redrilled for the Chevy bolt pattern.
The car had an S10 rear when I got it and since I was re-doing all the rear end stuff anyway...
But it sounds like you'd be money ahead just reworking the stocker.
Trifive Calendar Editor
I agree that a stock rear will hold up for your setup. If you're convinced you need something stronger but don't want to spend the big $ - You'd do well with a Ford Explorer rear from a parts yard. They are quite strong, a good width and the newer ones have disk brakes.
1957 Belair wagon, 51 HenryJ
If there is nothing wrong with the original diff why change it. I have a 73 Ventura(Nova) 10 bolt under the wagon. I had to weld on new spring perches and shorten the driveshaft a bit. Good day.
I have a 9" out of a VerSallies, got it for the disc brakes, gave 500 bucks for it about 10 - 12 years ago. But, a 10 or 12 bolt would work just fine, works like a charm, put brake pads on it one time, just got it cause it was handy and close to home. Can't tell from a '55 rear. Running a 350 330hp w/turbo 400, the thing has 2:73 gears, fun to drive. Later, Charles :wavey:
DS,
P/M me if your serious about the third member. If the price is right I might be very interested.
Thanks, Brian
I'll talk to him and see if he will make a reasonable price on it, he was asking more than I thought it was worth, but what do I know... They are around $1300.00 new...
1 - 20 of 32 Posts
