Im welding 1x1 16ga tubing, i have a 125 cylinder of argon/co2, seems like i went through my big cylinder really fast.
My welder is a hobart 140 its set on #2 with a wire speed around 40. The gas was set to around 15 but it seemed like it was using too much so i bumped it down to around 5-7 and it still seems like it is still using too much. Whats the right amount of gas and how long should it last?
member
At 15 CFH you should go through a 125 CF bottle in a little over 8 hours of welding. If it welds okay, turn it down some more.
I use 15 to 17 cfh.
Make sure you are reading the right scale on the gauge.
Mine was counter intuitive and when I saw I was using gas kind of fast, I realized that I was reading the metric scale and had it set too high.
