I bought a new horn cap and emblem from Danchuk because my the one that is on my car now is worn out and the emblem says 210 and mine is a belair. I noticed the two bolts that hold the horn cap on (bolted though the steering wheel) have a weird head on them...it's definitely not a phillips, flat, allen head, etc... so what kind of head is it?? What kind of tool do I need to do this thing off?? ......................and can somebody tell the purpose of these odd ball bolts?
Thanks guys..
JiM
Bakersfield, Ca
I don't have one to look at but I think it is most likely a Clutch Head screw..
does it look something like this pic??
In a pinch, a clutch head screw can be driven by a slotted screwdriver.
I'm pretty sure that is the one......will a hardware store carry that head?? Why is that head used on those bolts???
Not sure if they're used much anymore but if you shop around the drivers are still available...
You can find a clutch head screwdriver set either on e-bay or www.hhclassic.com has them. I believe they are usually around 19.95 for a set of 5. If you do any work on the tri-fives you`ll need them anyway.
