1 - 20 of 35 Posts
What are you pros,........... using to mix up your body filler[bondo] on? I used wall paneling, cut up in squares in the 70s,cardboard,. marson paper sheets pad.Maybe you have A mixing pad you are partial too? Maybe
buying A plastic board ?? what thanks ? all bob s:bowtieb:
I buy a board at the paint store that has a tablet of tear-off pages. No clean-up. just tear off the sheet and throw it away.
DITTO, has a nice thumb hole for better control. Cardboard boxes work well also.
I use a 12"X12" pc of 14ga with a tin pull handle welded to the underside, look kinda like a drywall mud board. Works great! Jim
Banned
When I forgot to clean the toylet lid or cant fid it, empty 30 pack cardboard is slick and works well. I also use a piece of the orginal hood of my 56, its been around almost 40 years in this capacity.
12x12 sheet of 1/8 inch hard plastic don't remember where it came from but cleans easy with lacquer thinner.
Later,
Kev
I use a piece of 3/8" thick plexiglass, about 8"x12"
Discussion Starter · #12 ·
What A great forum ...with guys like this around, in this thread. Anyone should be able to build a 55-57 or whatever.THANK YOU ALL! IDEAS Are what i asked for ..and thats what i got!:rock: cheers bob s
an old thin plastic cutting board from the kitchen work well and when you have to clean up, flex it and all the mud pops off.
I use the stiff papaer plates. just toss when done.
I'm another plexi-glass fan.....have always used this as a mixing board....I cut a thumb hole out the one side....last for a long time...easy clean-up with lacquer thinner. Also......I put the spreaders, (if you are using the older plastic type) in a container standing up for a while, then wipe off the softened filler and wipe clean. I have seen some of the cheaper/newer spreaders melt in the lacquer thinner if left too long!!
Lacquer thinner can be nasty....I used to know a refrigerator repair man who would cut up broken pieces of the inside plastic in your fridge....put them in a can and cover with lacquer thinner.....after it all melted together, (it turns into a thick gluey substance) he would use it to apply to cracks in the plastic lining to fuse it all together....instead of the ever-popular Duct-tape!!:sign0020: A winter project for your old fridge in your garage guys.
Then put it back in the cupboard.....she'll never know!
1 - 20 of 35 Posts
