1 - 11 of 11 Posts
The very bottom of my radiator has a circular indentation, which is dripping pretty bad. Is there supposed to be a plug or something? Its in the very center of the bottom of my factory original radiator
Since your adding A/C to your car, I would suggest a more efficient radiator at this time. If it's original, the tank is probably paper thin.
Would an aluminum factory style one do the trick? Also, is there a way to fix this perhaps without buying a new radiator?
No plug in the middle.
On the front of the radiator there should be a tap on the pass side. On the rear if you have auto transmission there is two lines on the left & right hand side of the bottom tank.
oooo boy, alright so its probably a full on leak of some sort. The dent is so perfect and centered though, it seems like its supposed to be there. what could i use to seal it up?
Yea i have those notches on the very bottom on the sides of the radiator, but my hole is on the very bottom of the radiator, lined up with that center notch
If you insist on fixing the leak, simply take it out, clean up the leak area & solder it.
ken 57bowtie-trifive
If you solder it, get some good liquid flux.
Don't waste your time especially since you are installing A/C. Get a new stock style aluminum radiator and call it a day.
1 - 11 of 11 Posts
