With 2 inch drop spindles and one inch drop springs and 2 inch drop rear springs I have been having trouble dragging my headers.
I put new tri y headers on and a year ago or so I side mounted the engine, replaced the PO installed (if you can call it that :rolleyes: ) angle iron crossmember for the TH350.
All of that combined got me some more clearance, but I would still scrape from time to time.:confused0006:
I took a measurement for how much they needed to raise. About an inch and a half.
Determined the angle of the down pipes to be about 45 degrees and that to move them up I needed to cut about 2 inches out. Cut grind, weld, done.
So, if anything scrapes now it'll be the frame. :s:
Seemed to be just right.
They moved up the desired amount, but they also moved forward. (knew that would happen)
I just need to add about 3 inches to the exhaust pipes to fill the gap.
I'd just pull the whole thing forward, but the servos for the cutouts would hit the trans crossmember. :(
Getting there. I'll stop tomorrow and pick up a piece of tubing to cut, fit and weld in place and I should be good to go again.
I have good clearance between the top of the header and the floor.
These being tri y headers, there's only two pipes going down to the collector. If they were standard 4 tubes I wouldn't have been able to weld all of the pipes all the way around.
I would have just bought new headers.
So, it saved me a couple hundred bucks or more.
:tu
These were coated, but where I cut them you can't see it down in there and I hit the weld areas with some hi temp silver header paint.
They'll last long enough for me. :D
nice job jeff. :five:
Discussion Starter #4
I got one side done and the other side ready to finish weld. I made some turn-downs for the cutouts as well.
I also made this little thing.
It goes here.
I ought to make a mold from it before I attach it I guess.
Console is really cool..:congrats:
I have those same headers and i really like how well made they are. And the try-y design should work good with my street combo. My 56 sets a little higher then yours. so as it is now i dont think i will have to many problems. Not sure how it will set yet till i get all the glass in. And the suspension has a chance to set. So im not changing anything yet.
I was thinking the same thing cutting them and moving them up if i had to. There is only the two pipes instead of four so that helps.
Did your driver side hang lower then the passenger before you raised them?
Mike
Discussion Starter #6
Yes it did. I actually cut and moved it up to match the other side first.
I thought maybe that would be enough. But, no.
I got it all back together today and took it out for a drive.
So far so good. I think I may need to mess with the back end of the pipes a bit to try and get them up as much as I can now.
And I'll have to get it on some lumpy road to really test it.
And I forgot to plug one of the cut outs back in, so I only have one working right now.
I'll jack it up tomorrow and plug it back in. Jack stands will be used of course.
Safety first!
nice touch on the console jeff. :five: ..........looks great :party0031:
