I bought mine from Danchuk. I had air shocks so I disconnected the air lines, disconnected top side of shocks from the body and compressed the shocks. I then mounted my crossbar to the shocks and manually extended the the air shocks until the cross bar was at the proper height with frame. Marked my bolt holes on the frame, removed the shock bar, drilled holes, and bolted it all together. Using the air shocks to position my bar helped me ensure I had clearance with exhaust pipes and ensure the top screw on the shocks did not hit the body.
Note installed the shock bar with the mounting brackets facing the rear of the car. This enabled me to move the shock bar forward enough to avoid interference with my exhaust pipes. The shocks are pretty much straight up and down when looking at them from the side of the car.
Todd
Todd
