Have a after market wonder bar radio. I have 6x9's back there now but I left the 2 smaller holes from the factory in the tray. Thought by making the hole the normal size for a 6x9 might help the sound quality.For a stock rear speaker installation, I'd leave the two holes in place and install a factory size 4 ohm 5x7 rear speaker (if you can find one) along with a factory style grille.
Do you have a stock radio (which one?) and the stock rear speaker control?
View attachment 365634 View attachment 365633
You are from the US but have a right hand drive? And your speaker holes are that far apart? Looks beautiful, but I'm confused.I cut mine. View attachment 365643
do you have the insulated back covers behind your speakers"I have 6x9's back there now but I left the 2 smaller holes from the factory in the tray. Thought by making the hole the normal size for a 6x9 might help the sound quality".
The new info says there's already 6x9's there.
Opening the other holes does nothing for the sound, except allow for some trunk cavity echo.
Being the car appears to still be operational, I'd guess the reduced structural integrity has not appeared yet, nor have the speakers and grilles fallen into the trunk. 😁
I haven't crawled in the trunk to measure my rear speaker, but I recall it's a 6x9."I have 6x9's back there now but I left the 2 smaller holes from the factory in the tray. Thought by making the hole the normal size for a 6x9 might help the sound quality".
Why would the speakers and grills fall into the trunk? They are bolted to the sheet metal of the package tray."I have 6x9's back there now but I left the 2 smaller holes from the factory in the tray. Thought by making the hole the normal size for a 6x9 might help the sound quality".
I appreciate your history of the package tray but what is your point?I haven't crawled in the trunk to measure my rear speaker, but I recall it's a 6x9.
I mentioned earlier about the factory using 2 small holes instead of 1 big hole for the rear speaker. We need to keep in mind how these cars were used when they were ordinary daily drivers, and most were not equipped with the optional rear speakers.
Back in the day, people would set all kinds of junk on the package tray. I think they called it a "package tray" for a reason.
I've even heard people mention sleeping on the package tray when they were little kids. Sounds insane today, but when the cars weren't even equipped with seat belts...
By making 2 smaller holes, things were far less likely to poke holes in the cardboard (no rear speaker) or damage the speaker grille (with rear speaker).
Now days, we wouldn't think of putting anything sharp or heavy on the package tray. But, back then...
No, why. My trunk is not wet nor dirty.do you have the insulated back covers behind your speakers
I use them to get better acoustics, not for dirt or moistureNo, why. My trunk is not wet nor dirty.
Got ya. So did you open up the 2 small holes and make one larger hole?I use them to get better acoustics, not for dirt or moisture
yes sir. If removing that small amount of metal hurts any kind of structural integrity it wasn't strong enough in the first place IMOGot ya. So did you open up the 2 small holes and make one larger hole?
