That is what I got from your statement above. I'm sure you can see how I got there.
I feel the need to respond to this point in case someone who didn't know a thing about stereos wandered across your post and took it the same way I read it, saying a 6x9 shouldn't even be an option as of course nobody goes out seeking poor quality sound. You're a respected member here, very knowledgeable on these cars, and I believe people hold your advice in a high regard. On this point however, you're off base.
What I mean by this is if we get in to an audiophile level discussion of the waves coming off a 6" round speaker vs. a 6x9" speaker, any distortion due to cone shape etc, that discussion is frankly irrelevant when the audio environment is this poor with subpar speaker placement and so many reflections. Of course this is the environment we have to work with, so we do the best we can. Car audio, like everything else, is full of compromises. Anyone building an audiophile stereo to the level to notice any minute difference in the distortion of waves between the 2 speaker shapes is not doing so in a 50s car interior.
Here's where you seem to have a misconception. The 6x9" has a larger cone area and is often just slightly
more efficient. As a very important bonus, the larger cone area lets it hit significantly deeper bass notes which is a definite plus if a person is not planning to install a subwoofer to fill in the low end.
Let's look at popular reasonable budget speakers from Crutchfield, all coaxial/triaxial (without separate tweeters). I promise I haven't cherry-picked these examples after looking at the specs, I picked the speakers before looking at the specs. 2 of these speakers I own personally, one in 6.5" (but component), one in 6x9" (but triaxial), I have no strong preference either way, whatever fits the application.
How to use the data below:
dB - Sensitivity - A higher dB number means more efficiency (more measured sound per watt at 1m, except Morel).
Hz - Frequency range. look at the lower Hz number as an indicator of how low the speaker can go. I'm less concerned with the high end as long as it's over 20,000Hz or so as that's usually 'high enough' for most music and most people over 18 start to lose high frequency above 17,400Hz, above 12,000Hz by age 50.
Infinity Reference Series
6.5" Round Coaxial
Infinity Reference REF-6532ex 93dB sensitivity, 57-21,000Hz range
6x9" Oval Coaxial
Infinity Reference 6x9 REF-6532ex 94dB sensitivity 46-20,000Hz range
Morel Maximo
6" Round
Morel Maximo Coax 6 - 91dB sensitivity 55-20,000Hz range
6x9" Oval
Morel Maximo Coax 69 - 90dB sensitivity, 45-20000Hz range
(note: Morel measures sensitivity at 2.87v @ 1m, rather than 1w @ 1m)
Polk DB series
6.5" Round -
Polk Audio DB 652 6.5" 92dB sensitivity, 40-22,000Hz range
6x9" Oval -
Polk Audio DB 692 6x9" 93dB sensitivity, 30-22,000Hz range
Alpine S
6.5" Round -
Alpine S-S65 88 dB sensitivity, 70-22,000Hz range
6x9"Oval
Alpine S-S69 90dB sensitivity, 65-22,000Hz range
Alpine R
6.5" Round -
Alpine R-S65.2 88 dB sensitivity, 65-40,000Hz range
6x9" Oval -
Alpine R-S69.2 90dB sensitivity 60-40,000Hz range
Kicker CS
6.5" Round -
Kicker 46CSC654 - 90dB sensitivity, 40-20,000Hz range
6x9" Oval (3 way) -
Kicker 46CSC6934 - 92dB sensitivity, 30-20,000Hz range
Kicker KS
6" Round -
Kicker 47KSC6504 - 90dB sensitivity, 43-21,000Hz range
6x9" Oval -
Kicker 47KSC6904 - 92dB sensitivity, 30-21,000Hz range
Summary: All but one speaker has better sensitivity (efficiency) in the 6x9" size of the same model. Every 6x9 has significantly lower range, which will be crucial if someone is not planning on installing a subwoofer, as many owners of trifives seem to choose.
This is why I choose to strongly dispute your statement
Someone following your advice would end up with a less sensitive speaker that can't hit the low notes. That isn't efficiency or quality sound in my book.
Well, here I am still saying otherwise. After looking up and posting the data, I don't think I'm being ignorant, do you?
And I don't think it's pride or consumer regret as I have both sizes in my last 2 stereos. I actually spent significantly more on the build that has the round speakers so if I was going to be proud of one of my stereos, it would be that one. I have the Infinity Reference Series (but the 3-way) in 6x9" in my '55 (chosen for the fit, and that I won't be running a subwoofer) I also have the 6" Morel Maximo components in my pickup (chosen for excellent SQ, along with a 12" Sundown subwoofer @ 500w RMS to fill in the lows). I regret neither purchase, or wish I'd have bought either in the other size. Both are a good choice
for their application.
I do always enjoy a good technical debate, especially with someone with some technical chops, so if you want to post up the data for a bunch of popular 6x9s that are grossly less efficient than their equivalent 6-6.5" round counterpart, or some data showing that despite hitting significantly more of the audible range, their sound quality is somehow worse, I'll gladly be proven wrong, always happy to learn something new.
Bottom line, you buy what fits the application, and avoid blanket statements like "do not even look at a 6x9 regardless of make or price".
